Here is info from workshop manual for front door. ignore battery cable part.
FRONT DOOR TRIM
FRONT DOOR TRIM REMOVAL/INSTALLATION
Disconnect the negative battery cable.
Open the cap using a small screwdriver, then remove the screw.
Remove the inner handle cover.
Remove the inner garnish.
Remove the cover, then remove screw A.
Remove the lens cover, then remove screw B.
Disengage clips A from the front door using a fastener remover.
Pull the front door trim upward, then disengage tabs B from the front door.
Disconnect the power door mirror switch connector and the power window main switch connector (driver's side) or power window subswitch connector (passenger's side).
