wiring....
Old Sep 19, 2007 | 06:26 AM
Mazda6kid's Avatar
Default wiring....
I just bought an undercar neon kit from streetglow and i need help....
they want the transformer under the hood on a metal surface...
but there is absolutley no space to put it (that i can see)(can i put it in the trunk)
and also i dont see any openings in the firwall to do the wiring...
does anyone out there now how to work around this issue???
Old Sep 19, 2007 | 11:49 AM
dentinger's Avatar
Default RE: wiring....
look under your driver's dash. there will be some grommets somewhere up in there. thats wat i used.
and does the transformer have to be grounded??
if not, just stick it on any flat surface.
oh wait, u drive a mazda6... meh, just look around..
Old Sep 20, 2007 | 08:18 PM
Mazda6kid's Avatar
yea the transformer needs to be grounded...im thinking about putting it in the trunk b/c at the top of my trunk there is a nice spot for it where the sub is for my bosestereo system...it would be a good spot but the now the wiring isnt long enough so now i need to buy extensions....
i also need to buy extensions for the under kit because they arent long enough either....
they should increase the length of wire that they give with the kit...
Old Sep 20, 2007 | 08:31 PM
dentinger's Avatar
well you could always put the transformer under your dash or where ever, the put the ground somewhere on the firewall.
as for extending the wiring, just buy the same gauge wire, and your set. make sure you sauter (sp?) the connections too, and cover everything up. you dont want water getting in there
Old Sep 21, 2007 | 01:29 PM
He means solder the wires. Yeah, good advice. ALWAYS solder where/when possible.
Get some of the correct sized heat shrink tubing for the individual soldered wires, some silicon grease to coat the whole thing with (look in the plumbing section of your local Home Depot. It's messy but well worth it,) and some wire loom that you can electrical tape over the entire run of wire and you should be set for a long, long time.
Bye-bye post #700!!
keninn
Nov 6, 2006 11:23 PM
reissigm
Dec 29, 2005 10:58 PM
the_gray_mazda6
Sep 13, 2005 07:09 PM
snesar
Jul 7, 2005 03:30 PM
markybhoy
Jul 2, 2005 08:34 PM
