faulty alarm
Old Aug 11, 2004 | 07:54 PM
callyboy's Avatar
Default faulty alarm
hope someone can help ?
My dad has a mazda 6 & the alarm keeps on going of for no reason.
Mazda have looked at it & say there has been some problems with the 6's alarm system but they do not know what is to blame.
they checked his alarm out & say there is nothing wrong with it, My dad asked them to put a different alarm in his car, but the guy at the dealershp said that this was not possible as the alarm was built into the car, & that the existing alarm would not allow a seperate alarm to be fitted.
Is this ture or not ? I suspect it is not true.
Old Dec 17, 2004 | 05:00 AM
bluemikecheck's Avatar
Default RE: faulty alarm
Yes it is tue about that the alarm system is built into the car. I am not sure about replacement but tell your dad to check his manual. There is alot of things that could set of the alarm. it could be at the door, trunk, weels, hood, windows, and a few other. This is all the places that the alarm has sensors on the car. U might also want to check his remote(keyless entry). The panic button might have a fault in it. Tell him to ask the dealer for a new one. they should give a one for free.
Old Apr 20, 2005 | 04:45 PM
fordice's Avatar
I had the same problem. The alarm system would activate if i walked past the car or if my mobile rang whilst standing by the car. Normally in the middle of the night!
The main dealer has just resolved by changing the interior sensors.
Old Jul 9, 2007 | 09:42 AM
monica85's Avatar
Was this covered by warranty?
Old Jul 10, 2007 | 03:27 PM
QuickerinSilver's Avatar
u kno wen i bought my 6 they sayd it didnt have an alarm but 1 day i pulled the door handle to open it (i forgot it was locked ) and it went off on me but the dealer sayd i didnt have 1....aint that a son of a bitch?!
Old Jan 25, 2017 | 08:02 AM
Kelly Dutton's Avatar
I pulled up to get gas and opened the door to get out and alarm went off. I pulled the fuse. Drives fine without it, but I lost the radio and all my digital info about the heat and air. Heat and air work, I just cannot see where it is blowing or temp. I would like to get this fixed.
Old Jun 15, 2017 | 07:31 AM
wbhill03's Avatar
Default Alarm blowing Mazda 6
I have had problems w the alarm going off at any time 24/7. The sunroof drain was stopped up by tree pollen and water got into the computer located in the kickpad beside the left driver's foot.. I replaced for over $1000. The replacement computer took on water and the dealer replaced 6 mo later under warranty. Good luck w this issue.
Old Aug 23, 2021 | 09:46 PM
LLDRIFTER's Avatar
Default Faulty door sensors I think.
Similar issue with my 2010 Mazda 3 alarm. Random any time. But I am noting the door sensor is activating "open door" and it goes on and off. That would trigger the alarm. That has to be the cause but how do you fix it?
Kielan O'Neill
Apr 18, 2017 03:26 PM
searcher
Mar 17, 2016 09:24 AM
cumbrian
Nov 17, 2010 02:02 AM
mlmazda
Jul 8, 2007 07:16 AM
s018mes
Apr 24, 2007 08:01 PM
