Auto window
Old Oct 4, 2007 | 05:37 PM
Lindyrect's Avatar
Default Auto window
So, I took my CX-9 to the dealer and they programmed the second remote that I never received with my car. My auto down and up window function does not work not to mention the 2 step down function. I opened the manual and followed the procedures to re-initiate both options and they did not work. Anyone else have this problem?
Old Oct 5, 2007 | 12:19 PM
imamgcx9's Avatar
Default RE: Auto window
Lindy... I'd run into this when our battery was jumped ( airport parking... long story )... and had to reset the window functions... I read that you followed the procedures in the manual... I'll just say this.. when I first did the same... it didn't seem to take ... I tried again later... and all is well...If it still doesn't work.. take it back to the dealer...
Old Oct 11, 2007 | 08:59 PM
Lindyrect's Avatar
Still no love on the window. I will have to go to the dealer and asked what they did to disable my auto down and 2-step feature.
Old Oct 27, 2007 | 07:46 PM
Lindyrect's Avatar
Update... Seems that the window switch in the door failed. It has internal transistors in the switch, I guess, and they failed. The dealership replaced the switch and all is well. Wow, one month of ownership and the switch fails!!! Is this a bad sign???
Old Nov 8, 2007 | 09:39 AM
tachicardia's Avatar
is this feature standard on sport, touring and GT? We pick up ours tomorrow and I wanted to know this.
Thanks,
-- Eric
Old Nov 8, 2007 | 06:35 PM
Lindyrect's Avatar
This feature is standard on all models with power windows, which should be all.
Old Dec 10, 2007 | 01:26 PM
michaelnwood's Avatar
another fix to this if you ever disconnect the battery is to put the window all the way down, then pull up on the window switch and hold the switch for an additional 3 seconds. I am told this will reset the switch.
Old Dec 13, 2007 | 06:03 PM
Lindyrect's Avatar
Well the manual say roll window all the way down and pull up on the switch to roll window up and hold switch for 3 seconds. You will hear a slight ping in the door and it should have taken, but if the switch is faulty like in my case you can do it till the sun goes down with no sucess.
nealward
Jan 19, 2020 02:00 PM
HerrKaLeun
Aug 4, 2013 08:34 PM
nicothehut
Oct 1, 2012 08:15 PM
davyrob_mazda3
Feb 20, 2010 02:09 PM
Mazda5 Mom
Sep 19, 2009 03:38 PM
