Transmission
Old Sep 11, 2005 | 11:29 PM
mission3713's Avatar
Default Transmission
I have a 02 Protege and i am wanting to check the transmission oil level. Is their a screw or a window to look through for this because i am not seeing a dip stick for it under the hood or maybe im not looking hard enough? Thanks for your help
Old Sep 12, 2005 | 01:41 AM
gwdevo8's Avatar
Default RE: Transmission
Is it an auto or manul
Old Sep 12, 2005 | 02:14 AM
sorry about that it is manual transmission
Old Sep 12, 2005 | 09:45 PM
There is a plug at front of trans near radiator that serves as both refill and check plug. Oil level should set so that oil just dribbles out when this plug is removed. Need a 23mm wrench to take out. 75W-90 recommended oil and should take a little under 3 quarts for a complete drain and refill. Sent a picture as well.
[IMG]local://upfiles/1377/0DCDE2D657374CCB96C5724FF6153611.jpg[/IMG]
Old Sep 13, 2005 | 11:42 PM
ok thank you very much but if i could ask you another question if it is indeed to low will the check engine lite or an check oil light come on. Also the car has about 70 thousand miles on it but probably only 60 thousand on the new tranny should i change the tranny oil i heard its not necesarry to change manual transmission oil thanks again
Old Sep 14, 2005 | 09:40 PM
There are no warning lights of any kind for a low transmission oil level. Changing the transmission oil is an excellent idea. Oil still warms and cools like motor oil and can get moisture in it from the air as well as metallic debris from moving gears and synchros. Cheap insurance to spend $10-$15 for 3 qts of gear oil to help protect a $3000 transmission.
ZoomZoomBoom?
Mar 10, 2011 09:59 AM
