Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Pickup Trucks
Old 10-24-2007, 01:17 AM
Chris1234 Chris1234 is offline
Default More Power ou of B2000
Hey, Im just wondering what are some ideas for getting more power out of a 1986 B2000. Any ideas from good intakes to super chargers, and anything else Im just looking for options. Thanks, and go shift some gears Register today for free or log-in if already registered to remove this ad!
Old 10-24-2007, 07:58 AM
hixx hixx is offline
Default RE: More Power ou of B2000
Headers, Different carb/intake setup would be the easiest. I think Weber makes a carb for it. Keeping the valves adjusted and cylinder head retorqued does wonders for power.
Old 10-24-2007, 09:02 PM
Cool, thanks I'll definetly have to try those. How often should the valves be done approx?
Old 10-25-2007, 09:34 AM
30k usually
Old 10-26-2007, 12:56 AM
Oh well then I think im definetly due.
Old 08-10-2009, 03:57 AM
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
There are companies that sell a weber carb kit for converting the truck. There is the 32/36 which is the most common, it is a progressive carb and usually does a good job and increasing the fuel milage and performance of the truck. Then there is the 34/34 many people complain about that one. There is also the 38/38 it is mainly a performance carb and the primary and secondary open at the same time. Many people adapt Holley 5200s which where liscensed from weber but require more know how since there are several dozen different variances.
Pacesetter makes a set of headers, importperformanceparts.net has performance valves that interchange from the 8-valve 626. Many rear wheel drive transmissions can be easily modified to fit by swapping out the bell housing and tail housing. I'm running a miata transmission in mine which does nice, gives it more of a car feel instead of shifting every 10 mph. LSD from the 1st and 2nd gen RX-7s can be interchanged if you know how to change and align the ring and pinion. The rest is pretty much engine building and would either require head work or rebuild work.
There is all kinds of information on the following page:
B2000 Tech Section
Old 08-26-2009, 11:08 PM
broncosis broncosis is offline
could just skip it and put a f2t in it or a fe-dohc
fuel injection is worth it
90 ford probe gt fe3t (it only thinks it is a ford)
fe3
custom turbo header
mega squirt
edis
second gen struts and springs
17" enkie rp02
car page
87 bronco2 bush/work truck
beat on regularly fixed rarely
Old 08-27-2009, 07:39 PM
Sure if he wants to modify the intake manifold and convert to a distributorless ignition....
Old 10-25-2009, 09:58 PM
a_cmc_2b a_cmc_2b is offline
Currently have the pacesetter header & the weber progressive carb but can't say anything about them yet, as I need to clean or replace my fuel tank...Will let ya'll know what I think as soon as I get a few miles on it...
2000, 3236, 929, b2000, bb, dgv, mazda, more, pinion, power, ring, weber
