truck will not run
Old Nov 6, 2005 | 05:03 PM
flyby's Avatar
Default truck will not run
1991 b2600i 2.6 engine Was going to replace valve cover gasket, so i degreased engine.
Well after that it has not ran since, Ive checked to see if i was getting fire to plugs and
it's not. I've dried the dist. It had a little water in it and pulled the connecter to dry it and it sparked.
Can any boby help???
Old Nov 8, 2005 | 10:48 PM
Default RE: truck will not run
Did you also dry inside the cap as well? Make sure you go thru and dry the distributor out as well as possible and also the connectors for distributor, air flow meter, etc. Is obvious that water has shorted something out and once dried should be ok.
Rod Holder
Feb 22, 2020 09:28 PM
7046fred
Mar 11, 2014 07:11 PM
RyanGL
Aug 8, 2011 08:04 AM
Tia
Aug 17, 2010 02:18 PM
Pochi09
Aug 3, 2010 05:11 PM
