headlight fail
Old Aug 21, 2008 | 02:37 AM
mazdacreep's Avatar
Default headlight fail
newbie here.. how would the low beam headlights on a 1999 Mazda fail?..dont have enough idea for this..i want to repair it myself..
_________________
mazdacreep6576232
Old Aug 21, 2008 | 02:51 AM
mazdacreep's Avatar
Default RE: headlight fail
I had that problem once. I found out that lights fail due to a faulty switches on the steering wheel console. So i pull it apart and clean up the contacts. good luck..
tnx..dats a good point
Old Aug 22, 2008 | 12:58 PM
Could also be a bad connection to/at the relay or a bad relay too. Sometimes the internal contacts of a relay get dirty or burned and fail. I would check for power there first. If you have power but no lights you know it's the relay. If not, probably the switch assembly.
Old Aug 28, 2008 | 04:34 PM
leftright's Avatar
headlidgt is easy to replace, open hood turn app 1/4 way pops right out . when installing new bulb first wipe with rubbing alcohol when installing don't touch with fingers use gloves (oil in hande causes failure.
Andorphin
Sep 30, 2011 12:23 PM
apbbnbanb_07
Apr 8, 2010 04:24 PM
VB
Jul 25, 2009 06:55 PM
mazdaspeed33
Jul 10, 2009 07:38 PM
Siber Express
Jun 2, 2009 03:29 PM
