daytime running lights or DRL’s
Old Nov 25, 2005 | 03:05 PM
amitr's Avatar
Default daytime running lights or DRL’s
Hello,
I am moving from Michigan to Toronto and I found out from Mazda that in order to comply with Canadian requirements I have to install daytime running lights or DRL’s.
What is this thing? How much should it cost? Is is something that I can install myself (without voiding warrenty)?
Can I have it installed in the US (would it be cheaper, what kind of shop would do that)?
thanks for your help.
Old Nov 27, 2005 | 12:43 AM
Default RE: daytime running lights or DRL’s
Daytime running lights or DRL means that your headlights come on automaticaly when engine is running unless the parking brake is engaged. It is Canadian Law. What model year is your MPV. Am looking at 2004 MY wire diagram and looks like you may only need to install a DRL control module if the wiring is in place for it which it probably is. And no it will not void your warranty as it is a factory option is some area's.
Old Nov 27, 2005 | 10:44 AM
amitr's Avatar
Thanks for the information. It is 2003 Mazda. Is it something that can be done in the US?
Old Nov 28, 2005 | 12:06 AM
Let me take a look tomorrow when I get back to the daily grind to see if wiring is there and what a DRL module will set you back.
Old Nov 28, 2005 | 03:31 PM
Will not be going thru Mazda for this one. It is not an available accessory to add on. Would need a DRL module and the dashboard harness and probably much more. The dash harness alone is $1700.00!!!.
Would look at going aftermarket. Check some of the local parts stores to see if they carry a kit to have this done. Found a few on the internet to look at and there are probably a zillion more.
http://www.automotiveelectronicacces...aeapn480hd.htm
http://www.daytime-running-lights.com/
2slow
Nov 9, 2010 09:57 PM
JoeBlow
Oct 27, 2007 01:08 AM
jrross
Jun 1, 2007 07:19 PM
JoeBlow
May 12, 2007 11:53 PM
bmgoodman
Dec 28, 2005 12:52 PM
