Old 11-20-2008, 08:44 PM
Kasstastrophy Kasstastrophy is offline
Send a message via Yahoo to Kasstastrophy
Default How To: Fixing a missing radio code.
If you are like me, you possibly might have the nice Panasonicradio that requires a code to be inputed if it lost power. Now, if your really like me... you didn"t have the code needed. Here are the steps to reclaiming your tunes and your sanity.
If you know the Owner"s Code, a four-digit code, the instructions are fairly simple:
STEP 1: Turn the ignition to ACC
STEP 2: Briefly and simultaneously press both SEARCH and AUTO-M. This action should change the display from a blinking code to a solid .
STEP 3: Using the radio preset buttons 1, 2, 3, and 4, set the Owner"s Code in the display. The first position can be set using the 1 button, the second using the 2 button, etc.
STEP 4: Press and hold both SEARCH and AUTO-M until you hear a loud beep and the display shows good. The radio will then turn off, and you are ready to start listening again.
If you don"t know the Owner"s Code, the instructions are similar.
The first goal is to get the display to flash"ERR" instead of code. Then you can enter the Dealer Code to reset the radio. Here are the steps:
STEP 2: Briefly and simultaneously press both SEARCH and AUTO-M. This action should change the display from a blinking code to a solid.
STEP 3: Using the radio preset buttons 1, 2, 3, and 4, set any four-digit code in the display. The first position can be set using the 1 button, the second using the 2 button, etc.
STEP 4: Press and hold both SEARCH and AUTO-M. If by some chance you guessed the Owner"s Code, there will be a loud beep and the display will show good before the radio turns off. If this happens, you are done. More likely, the display will briefly show"ERR" and then change back to the flashing code.
STEP 5: Repeat steps 1-4 until you have a flashingERR instead of a flashing code.
STEP 6: Press the following buttons in sequence: SEARCH, AM, AUTO-M, FM 1/2. The display should now show .
STEP 7: Set the code to 4989 using the preset buttons, as before.
Press and hold both SEARCH and AUTO-M until you hear a loud beep and the displayflashes good. The radio will then turn off, and you are ready to start listening again.
This will speed you on your way to getting your radio back!
-Kass
"No matter the obstacle big or small, it can easily be overcome with large amounts of high explosive."
Old 11-21-2008, 12:53 PM
virgin1 virgin1 is offline
2004 Mazda Mazda3
Default RE: How To: Fixing a missing radio code.
EXCELLENT write-up, Kass!! Excellent job.
FAQed and Stickied!!
Old 12-21-2008, 12:10 PM
chargit chargit is offline
Wow, this is very good info. I am a used car dealer and this happens alot on the lot. a battery runs down, or is replaced and bam!
Thanks a bunch!
Tracy
Old 10-22-2009, 02:46 PM
keninn keninn is offline
great for 95-96. 97- no code needed.
2008, 323, code, display, fd, lost, makes, mazda, millina, radio, resetting, rx7, rx8, stereo, turn
