2005 mazda tribute electrical problem
Old Mar 2, 2009 | 05:36 PM
craziecracker's Avatar
Default 2005 mazda tribute electrical problem
i have a 2005 mazda tribute and im having a big problem. there seems to be an electrical problem with the vehicle. the sunroof controls, windows, lock/unlock buttons do not work. the headlights do not come on and the rear wiper does not work. also, the emergency brake light is on on the cluster. all fuses are good and i changed all the relays. anyone have any idea???
Old Mar 7, 2009 | 10:39 PM
carfixer2's Avatar
The smart juntion box has probably failed .It is located in the center console area and it will have to be programed as well. [Might have to get as built data] Be sure to check all fuses in the fuse box under the hood and in the smart junction box. I hope this helps kevin
Old Mar 26, 2012 | 01:24 PM
rosaliemagro's Avatar
Default Mazda Tribute Electrical Problem
The right signal is permanently on and it doesn't blink to turn right. I've been told that the right turn signal and the wipers are on a combination switch so i ordered the part and it didn't make any difference. I checked the module for the trailer hitch. We had a diagnostic done on it and everything checks out fine (green light). Doesn't anyone know what else we can try? Thanks in advance.
Mazda4Me
Apr 23, 2014 09:10 PM
Shiloh Greenwald
Mar 16, 2014 04:00 PM
KMag
Nov 24, 2013 05:54 PM
GinoRP
Jun 15, 2012 05:06 PM
sweetmarie
Mar 15, 2011 01:08 PM
