dash lights and parking lights not working
Old May 3, 2009 | 12:54 AM
jpaschal21's Avatar
Default dash lights and parking lights not working
My dashlights and parking lights aint workin on my 88b2200 if anybody knows how to fix please let me know
Old May 6, 2009 | 12:29 AM
Cusser's Avatar
Do the taillights work? They should be on same circuit as parking lights. Have you tried jumping or turning the rotary switch on the dash to see if that makes the dash lights work?
Old Jun 16, 2009 | 11:35 PM
sdinant21's Avatar
i have 97 protege park lights and cluster light went out replaced fuse for park lights they worked for a little while then it blew again, all warning lights work in cluster all work except for the back lights to see speedometer at night is that a bad switch????
Old Jun 17, 2009 | 07:59 AM
hixx's Avatar
Did you install a new radio recently?
Old Jun 17, 2009 | 09:39 AM
sdinant21's Avatar
no new radio only thing new installed before this happened was a battery by autozone
Old Jun 17, 2009 | 06:56 PM
sdinant21's Avatar
ok after searching all around i took dash apart at the relay it has 4 wires on it 2 power in, 1 to the switch, last power out. the power out had a break in it causing the fuse to blow and melting the coating on that wire which now has to be replaced thanks for any help previously and hopefully this can help others
CanAva
Jun 9, 2019 07:35 AM
Auburngal
Jan 17, 2012 08:52 AM
SanCarlos_Tribute
Feb 28, 2011 08:19 PM
doctor_joe87
Feb 15, 2009 08:59 PM
anthonytsi
Nov 12, 2008 04:37 PM
