2000 MPV headlight beam too high
Old Jun 13, 2009 | 08:14 PM
thelordparadox's Avatar
Default 2000 MPV headlight beam too high
For some reason my 2000 MPV's right headlight beam is higher than the left. The owner's manual does not show how to adjust the height. Does anyone have this problem? Is there any way to adjust the lights without seeing mechanic?
Old Jun 13, 2009 | 08:58 PM
NightSwimmer's Avatar
I replaced a lamp in my Honda's headlight once and it wasn't seated in the socket properly, although the retainer clip was secure. That caused the aiming to be off and I had to re-seat it. It didn't help that I was out-of-state in a Wal-Mart parking lot at night when I replaced it. ;-)
Almost all headlights have two adjustment screws. One is directly above the headlight and the other is on the outer edge of the headlight. (right side on drivers - left side on passengers) Counter-Clockwise moves the light 'out' -- Clockwise moves it 'in' toward the engine compartment. So it sounds like you need to turn your top adjustment screw slightly CCW on your right headlight.
It is best to park on a level spot squarely in front of a brick wall to adjust the headlights. Then you can use the brick lines as a guide to see the beam moving as you adjust them.
Neil Everett
Feb 27, 2021 03:52 PM
cbt1967
Mar 1, 2014 04:08 AM
pkepneriv
Dec 9, 2010 09:34 AM
mazda guy
Apr 27, 2009 07:48 AM
57chevy
Jun 2, 2006 01:06 AM
