Mazda3 - Air Conditioning - Stopped Working
Old Jun 18, 2009 | 04:23 PM
heyyou82's Avatar
Default Mazda3 - Air Conditioning - Stopped Working
All-
I have a Mazda3 that the AC has stopped working. When the light comes on in the dash when the button is pressed, no fuses appear to be blown, but the clutch doesn't appear to be engaging for the AC compressor.
I have been trying to find an electrical diagram so I can test along the way, to no avail.
Does anybody know if AC problems will be logged as DTC codes? If so, will a generic OBD-II reader catch them?
Old Jun 18, 2009 | 08:07 PM
Tracker's Avatar
what year, check for tsb's and yes
Old Jun 19, 2009 | 08:40 AM
heyyou82's Avatar
Sorry, it is a 2004 3i.
Old Jun 19, 2009 | 11:05 AM
Tracker's Avatar
you should go to a dealership and see if there are any recalls on that, if your cel light is on then a OBD2 code reader should be able to pick up the problem. Im not that familiar with A/C systems yet so my suggestions are limited
Old Jun 19, 2009 | 04:35 PM
heyyou82's Avatar
To clarify, the car does NOT have the MIL on.
Old Jul 2, 2009 | 10:53 PM
copierman's Avatar
is the refrigerant pressure in the A/C system okay ? Have known compressures to not work if insufficent coolant pressure in the system. Not sure about mazda A/C sys.
Old Jul 3, 2009 | 04:08 PM
copierman's Avatar
further checking , mazda 3 A/C will blow hot if r-134 pressure low. dealer states if compresser not runing , the compresser is the issue . Abeit a pricey issue
Old Jul 3, 2009 | 05:11 PM
vlstellato's Avatar
Check your compressor,I had the same problem my clutch assembly fell apart.
Old Jul 3, 2009 | 08:02 PM
oldeng's Avatar
Also worth checking is your A/C relay. It is located in the engine compartment fusebox, and under the fusebox cover you'll find the layout and function description for the fuses and relays.
Old Jul 7, 2009 | 11:51 AM
heyyou82's Avatar
All-
Thanks for your replies.
I don't have refrigerant pressure gauges, so it is hard to diagnose that.
Agreed- no/low refrigerant will cause the system to not work (or blow warm air), but does anybody know if this will cause a DTC code?
A/C relay appears to be OK (swapped with a different relay, and no change).
The A/C light illuminates when the button is pressed, but as mentioned, no compressor.
So, I am trying to figure out if it is electrical or mechanical or refrigerant.
I am hesitant to bring to a shop until I have a good understanding of the problem, mostly because I am jaded (this problem seemed to start after car was brought in to a dealer to replace the tube that the gear selector passes from cabin to engine compartment or in other words, they had the dash somewhat apart).
