2000 MPV Trouble code P0421
Old Jun 20, 2009 | 02:04 PM
thelordparadox's Avatar
Default 2000 MPV Trouble code P0421
Autozone's analysis on my MPV's Check Engine Light says "Warm-up catalyst system (RH) efficiency below threshold".
What does that mean?
Old Jun 20, 2009 | 04:58 PM
NightSwimmer's Avatar
It means that the pre-cat that is hardest to reach (at the firewall) is operating at less than perfect efficiency. The downstream Oxygen sensor is active because of unburned fuel residue passing through the converter unconverted. It is a rather expensive repair -- even with aftermarket parts.
Other issues could be involved. If you have a leak in your exhaust manifold you can get this error even if your catalyst is good.
jroberts 312
Dec 11, 2024 03:33 PM
808mazdampv
Apr 8, 2011 03:18 PM
NightSwimmer
Mar 18, 2009 06:42 PM
maddflavor
May 22, 2008 04:51 PM
prostarthunder
Apr 9, 2005 04:37 PM
