using timming light!
Old Jun 22, 2009 | 02:25 PM
tommycat01's Avatar
Default using timming light!
Ijust got my belt on my 1988 929 and getting ready to put the timming light to it. My question is do i have to do any thing special before i time it with the light? Autozone said 15 degrees btdc. the tab has 10 and tdc and lines between them , is the little lines 1 degree? i'm new to this so any help would be greatly appreciated!! Thanks dave
Old Jun 24, 2009 | 11:14 AM
Gimme3Doors's Avatar
Usually you have to disconnect the advance and computer wire from the distributor when setting the mechanical timing. If there are vacuum lines leading to the distributor, pull them off and plug the lines. If a single wire also connects to the distributor, disconnect that also. The wire is different from the spark pulse wire.
There should be a decal under the hood that gives the correct timing, don't go by what a parts store says.
mike 02
Oct 22, 2008 07:16 PM
chevy
Mar 16, 2008 10:01 PM
axelnby
Sep 11, 2006 05:34 PM
Chubs
Oct 21, 2005 01:03 AM
