Old 10-27-2009, 12:28 PM
ylp07 ylp07 is offline
Quote:
Originally Posted by keninn View Post
0170/73-rt/lft bank fuel trim malfunction. most common cause for this is broke tees in the vacuum line system. there are 2 in particular that break all the time. the intake must come off to get at these. this is one of those jobs that if you dont want to be doing/paying for this over and over again, what needs to be done is change out all the vacuum line(21 ft) and replace several tees. i went to brass, which will outlive the car. the plastic will only break again. also, the vacuum leak(s) could also be the cause of your 1526/1540.
Is this something that I can do myself with basic car knowledge? Or am I going to be taking apart half of the car in order to replace the vacum hoses? How much would a dealer/mechanic charge for this?
1113-intake air temp sensor, compressor. this is easy to get to, just remove the plastic miller cycle cover, and you will see a cover plate with 4 bolts. this sensor is right near that plate. they generally dont go bad, i would just disconnect/reconnect it. there is a test, but you have to remove it, and put it in hot water, and measure resistance.
Thanks, will give this a go tonight.
1455-fuel guage sender unit malfunction. is your gas gauge off or not working? to get at this, you will have to drop the tank. a very messy job.
Twice in the last year, the gas guage would just drop the empty and stay that way for the drive. It would reset itself.
1526/1540-abv vent valve open or short/abv control system malfunction. this could be a lot of things. for one, it could be related to the 0170/73 vacuum line leak. another reason to change out all the lines and the bad tees. the vent solenoid is also a common problem. you can ohm the solenoid, and see, but a lot of the time, they will ohm good when cold, and when they get hot, then they fail. if that happens, then you get the limp home mode. i would change out both the vacuum and the vent solenoids, along with the vacuum lines and tees. your problems have NOTHING to do with the a/c system.
This definitly sounds like something I will not be able to do. Do you know what a fair price would be for a mechanic to do this? The reason I ask is because as much as I love this car, it might be time to put it out to pasture. It has 130k miles and has been into 2 nasty accidents (neither my fault, but not worth spending the 3-5k in body work to get it repaired...so I'm driving with my passengers side all crumpled up.
The reason I need to figure this all out is because my inspection sticker expires in November and it obviously wont pass with a CEL. However, I was really hopign to get her up to 150k miles before saying goodbye.
Thanks for your help. Much appreciated.
Old 10-27-2009, 06:41 PM
keninn keninn is offline
a competent mechanic(and i have yet to meet one that knows anything about this car-and that includes the dealer) would charge several hours labor alone. check around on what hourly labor rates are. just to change 2 tees cost me 564 parts and labor about 6 years ago at the dealer. parts were about 6 bucks, the rest was labor. that was the last time i took the car anywhere. after that, i learned how to fix it.
amsoil, shift, stinks, super
