climate control unit failure ?
Old Sep 23, 2009 | 10:28 AM
gomazdago's Avatar
Default climate control unit failure ?
After changing the Radio (and Bassbox) in my 626 GW 2002 the climate control unit doesn't turn on.
I have controlled the connectors are ok. Only 1 orange cable is not connected. I think it should connect to other orange cable which currently connected with a black cable (with a fuse 10A. Its ok)
http://www.imgbox.de/users/public/images/k21340g47.jpg
So i connect all 3 cables.
http://www.imgbox.de/users/public/images/x18738t47.jpg
But it still doesn't work. I dont know why ?! Is it there any fuse for this unit ?
thanks
Old Sep 23, 2009 | 09:19 PM
hixx's Avatar
Why were the wires to the climate control cut? Were they used to wire the radio? If so why? What does the fused wire go to? All the wires you could need were there from the factory radio so im a bit perplexed as to why the climate control wiring was even touched.
Old Sep 25, 2009 | 08:46 AM
gomazdago's Avatar
-Why were the wires to the climate control cut?
I dont know why, may be it cut while i change the factory radio.
-Were they used to wire the radio?
no, the factory radio has other wires, undepent from control unit.
-What does the fused wire go to?
I dont know? it goes to to the right ...
-All the wires you could need were there from the factory radio so im a bit perplexed as to why the climate control wiring was even touched.
I'm sure. control unit has other wire bundle as radio.
It's there any fuse in the fuse box for the climate control unit ?
Duckandmiss
Apr 3, 2013 09:18 AM
sonnystables
Jul 6, 2008 11:17 PM
kids
Jan 20, 2008 12:36 PM
kids
Jan 20, 2008 10:47 AM
dimas
Jul 3, 2007 10:38 AM
