Intermittent Electrical Problems
Old Oct 4, 2009 | 08:21 PM
kyushu2002's Avatar
Default Intermittent Electrical Problems
Zsdert
Old Oct 5, 2009 | 07:56 AM
Mazmart Trini's Avatar
Sounds like it could be the Body Control Module going bad. Looks like the vehicle is out of warranty by the mileage.
Old Oct 5, 2009 | 03:30 PM
Most of the items that are acting up, is controlled by the BCM.
Old Oct 5, 2009 | 06:53 PM
I'm not familiar with that either, Sheldon. Could you tell us both more about it?
How it works, where it is, what is does, etc?
Old Dec 22, 2009 | 05:14 AM
Nickerz's Avatar
This is interesting - this problem has just happened to me in Australia. 2006 Mazda 3 SP23, 41,000kms, service centre have just informed me it's the Body Control Module unit. And they want AUD$2651 for a replacement part. As I've just found used ones on eBay for US$99.99, I'll be debating that before the work commences.
Old Dec 9, 2010 | 09:38 AM
skidder!'s Avatar
One solution to intermittent or permanent headlight failure can be found on the post by SEVARGMT on 9-29-2010.
It seems to lie in corrosion of the wiring system connectors in the PJB, a specific wire connection junction box located under the passenger side glove compartment box.
It seems possible to repair the corroded pin connector but it is probably best to have the dealer replace the entire PJB to avoid repeats of this problem, as it is a dangerous situation when headlights go out at night, like mine did.
Brilliant problem solving by SEVARGMT and DJS2571. They also developed a convincing theory of what causes this problem: the air conditioning line located above this box creates condensation, which then drips down on the wire connectors and causes them to corrode, causing an electrical fault. They suggest a plastic drip sheet to avoid future corrosion.
Wouldn't it be great if Mazda assigned an engineer to read the forums for problems with their cars and prepare posts with solutions? It is plainly obvious that a problem is very common when you look at the number of "views" listed for certain topics, such the headlights (many thousands of owners have headlight failure problems). Mazda should have issued a bulletin or a recall since the corroding PJB is clearly a safety problem. This looks like a design/engineering flaw. Every electrician and plumber knows to never put moisture sources above electrical boxes. Shame on them.
donh215@gmail.com
Sep 17, 2022 05:38 AM
ryanhagfors
Aug 27, 2021 03:45 PM
GuyAndATribute
Jul 28, 2021 09:53 AM
Mr. Zeal Red
Jan 2, 2014 04:40 PM
steve405
Jan 2, 2012 11:52 PM
