Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda MPV
Old 10-08-2009, 12:06 PM
Skrappi69 Skrappi69 is offline
Default Breaking belts! Help!
My fan belts keep breaking on my 92 3.0L MPV. The fan clutch turns freely. The pully on the Alternator spins freely. When I put on a new belt it will loosen up as if it's stretching. I will adjust the alternator in the slide down to tighten it up but it eventually loosens up again. I eventually run out of room on the slide as I have to keep moving the Alternator down to tighten the belt. what could cuase this? I make sure the belt is not too tight or too loose. No more than 1/2 in play total. Meaning 1/4 inch flex on the belt at the top and bottom in the middle between pullys. Register today for free or log-in if already registered to remove this ad!
Old 10-08-2009, 12:13 PM
sstlaure sstlaure is offline
Check for any kind of pulley misalignment/wobble. That can stretch out belts quickly.
2004 Mazda6 Sportwagon
Any statements made are purely my opinion
Old 10-19-2009, 03:18 PM
zobploma73 zobploma73 is offline
Send a message via ICQ to zobploma73
Default Breaking belts Help
I am no expert but I havent lost a belt yet. I dont see the need for a tensioning screw it could encourage over tightening.To adjust the belt: I loosen the motor screws just until the motor moves freely, I then apply pressure using the motor, with my hand only and re-tighten the screws. Afterwords I check the belt to make sure it is tight but not over tightened. Ive only adjusted my belts once, that was when I setup my belt drives, well over a year ago ...... I am running 4 drives ...... Ive never jumped a tooth, never broke a belt. I hope this helps
626, 92, alternator, belt, breaking, mazda
