Old 10-26-2009, 05:14 PM
pops pops is offline
Default 1999 protege idle problem
1999 1.8L engine approx 110,000 miles
Just started to Stumble/Stall at idle
Runs ok above 1500 or so.
Cleaned idle/air??? control valve, had some carbon not much.
coil ohm = 8.7 bench test unit, operates but does chatter, I
don't know if that's normal or the piston should just clunk
open/clunk closed
Found cracks in air tube from air box "fixed" with
duct/foil tape
Idle got a little better, more stumble less stall
Connect scan tool w/ Digimoto software
P1170 fault, I reset and it has not returned.
At idle, fuel system 1 OL-Fault.
Above 1500, fuel system 1 closed loop.
Decelerating, fuel system 1 OL-Drive
Fuel system 2 OL-Fault at ALL rpm/mph
Would like to know what F/S 2 OL-Fault Means
Old 11-06-2009, 10:21 PM
air hose from air box is inexpensive item that should be replaced. tape is a band-aid approach, likely more crackscausing ECM to try to compensate for all the extra air.
Old 11-13-2009, 04:29 AM
darkstar4100 darkstar4100 is offline
replace that hose tape won't do anything one day your going to have a big vaccum boost and you will have tape inside the engine, ive tried the ghetto way on my car before and every morning you when you turn your key on you can hear the car pumping air back into all the hoses cause of the leak. fuel system ol-fault means- fuel system open loop fault. http://www.nitrod.com/articles/FuelSystemTA.pdf that link will tell you everything about open and closed loop systems its to much to explain on here. you will need adobe to open it if not let me know and i will explain it.
18, 1999, control, idle, mazda, olfault, protege
