Old 10-27-2009, 01:44 PM
lawdog lawdog is offline
2006 Mazda Mazda3
Smile Demon Eyes
So I decided I really liked the look of the Demon Eyes so I ordered the DDM DDE Lightening Raptor series! I read a few threads about the install and sort of got disheartened about the install. After reading the threads on other forums it seemed like a really difficult project to undertake. Well I finally got the cojones to install them this past weekend. I must say, the install was not nearly as difficult as I was lead to believe. It took me a few hours to complete and it was a slight pain in the butt, however, the outcome was well worth the trouble. If you are worried about the baking process for the headlights 200 degrees for 10 minutes will do the trick. If you think about it 200 isn't all that hot. It is just warm enough to soften the glue holding the lens in place. If you decide to do this mod, just make sure to take your time and don't rush through it. Some of the pieces can be fragile but if you give it a little finesse you'll be ok. I'll post pics as soon as I get my photo bucket account set up.
"Qui desiderat pacem, praeparet bellum"
-Flavius Vegetius Renatus
("Let him who desires peace prepare for war")
Old 10-27-2009, 08:11 PM
virgin1 virgin1 is offline
2004 Mazda Mazda3
Congrats, lawdog... and waiting for pics!
Frankly, I had the same reservations as you did. I went another route that was seemingly easier and longer lasting.
These are LED "eye lids." I connected mine so that they are always on when the ignition is. And, because of where I power then from, they stay on for a period of time after the key is turned off. (Timed off.)
Except for having to create a wiring harness and deciding how and where to run it, it wasn't that bad.
I hope for your future sake that you used clear silicone to install the bulbs instead of the double stick tape that comes with the kit. I know from others that it will eventually (+/-2yrs.) turn brown, where as the silicone won't.
"There is no tool you can buy that will replace experience." - Josh Mills, C.K.DeLuxe/Koolhouse Publishing
Old 10-27-2009, 09:24 PM
icspots icspots is offline
Yeah, the DDE's really aren't all that difficult to install, just a little time consuming. I think most people who have had problems with them are those who get impatient and rush through things.
I installed mine a few months ago (or so) as well. Sadly I had a few issues. First the epoxy I had set to quickly, then the right low beam halo wouldn't stick to the ring (took about 40 minutes to get it solid), then the next day the left low beam halo started flickering and ultimately crapped out. I removed that one and got it replaced under warranty, but I still haven't had a chance to replace it yet. I disconnected the right low beam one so at least the high beam ones are symmetrical, but I can't wait to have all of them working again.
Here's the one pic I was able to get of all of them working before that one died it's untimely death.
and just the high beam ones.
Old 10-28-2009, 12:33 PM
2006 Mazda Mazda3
Yeah I made sure to use the silicone. I didn't really trust that double sided tape with the heat! That really kind of sucks that your low beam crapped out. I don't think I would want to repeat the project anytime soon. Hopefully, knock on wood, mine stay fully functional!
Here are a couple of pics:
Old 10-28-2009, 03:51 PM
2004 Mazda Mazda3
Looks Good, LD!!! Congrats on a good install.
PMM I see? I like the Vibrant box in the bg too.
Remi, Y'know, I almost like it better w/o the low beams. To me it looks more sinister that way.
Perhaps when you replace the low beams you should put them on a switch so they can be turned off separately?
Old 10-29-2009, 10:55 AM
Theoretically that would be possible. That said each ballast has two outputs on it. As I have them now the ballasts are mounted under the headlight with a power/ground connection going to each from the car, then each one powering the halos on that headlight. You'd have to center mount the ballasts, extend the output wires from each one to go to both headlights. Again, doable, just not work I want to put in. Besides then I'd have to work out something else with my switch!
Old 10-29-2009, 03:47 PM
2004 Mazda Mazda3
Yea, but think how cool that would be.
Old 10-29-2009, 06:09 PM
2006 Mazda Mazda3
That is actually a really neat idea! I used zip ties to hold the ballasts in place so they would be really easy to move and center mount... Probably wouldn't be too terrible of a task to wire up a switch either. Good call Virgin! I may try that sometime in the near future. Gotta get my suspension done first. I may try and wire up some ambient blue lighting at the pedals too...
Old 10-29-2009, 11:22 PM
apbbnbanb_07 apbbnbanb_07 is offline
1993 Ford F-150
My Garage
What type of fuse system did you guys use for your lighting. And where did you run power from.
I have other lighting ran straight to the battery, with a fuse jerry rig'd in the circuit, is this not a good idea?
I was kinda leery about doing this, but was curious on what others have done.
..................................2008 Auora Blue Mica 2.3.......................................
The only difference between genius and stupidity, is that genius has its limits.
Old 10-30-2009, 01:52 PM
2006 Mazda Mazda3
I actually ordered mine as a kit from the rpmstore but its a pretty basic setup if you have a relay and ballasts. The main power line runs from the positive post on the battery to the relay. There is a 10 amp fuse is on that line between the battery and the relay. The relay then runs a ground wire (which obviously will be grounded), a power wire (which plugs into the empty accessory slot in the fuse box completing the circuit), and wires to both ballasts. The ballasts then run wires to the lights. Its pretty basic.
06, 2006, cx7, dde, ddm, demon, eye, eyes, halo, install, lightning, mazda, miata, protege, raptor
Vendor Directory
Mazda Parts
- All Weather Floor Mats
- Throttle Body Spacers
- Neoprene Seat Covers
- Dog Seat Cover
- Rubber Car Mats
- Husky Floor Liners
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
