Old 11-01-2009, 01:03 AM
phildavis111 phildavis111 is offline
Default 2001 Protege IAC Valve 1.6L
Does anyone know how to clean an IAC valve on a 2001 Protege 1.6L? I read that these are uncleanable and need to be replaced. That doesn't make sense to me as long as you were careful with the electronics. Is there a way to clean them without damaging the electronics? Any help would be appreciated showing the steps on how to do it? Thanks. Register today for free or log-in if already registered to remove this ad!
Old 11-03-2009, 09:16 PM
motorhead5673 motorhead5673 is offline
Are you having a problem or is this just preventative maintenence.
On my 00 i spray carb cleaner into the IAC port with the engine running. You'll have to keep the throttle cracked to keep the engine running and use short bursts of cleaner. You may need to remove the IAC and clean the tip with a brush (I'd use an old tooth bruch). Never had to take mine out so I'm not sure what's involved. Can't be too hard though. Thoroughly clean the throttle plate and TB if you haven't already.
Old 11-04-2009, 05:57 PM
Default 2001 Mazda Protege IAC 1.6
I've been having some rough idle. I checked the electrical contacts on the IAC with a VOM and it was ok at 10 ohms resistance. I want to dissassemble the throttle body and remove the IAC and clean it really good. I think the IAC might be sticking. I just wanted to make sure I didn't get any cleaner into the electrical part of the IAC. Did you use carb cleaner? How did you keep from getting the cleaner into the electronics? What do you have to do to expose the tip for cleaning? Thanks.
Old 11-07-2009, 05:06 AM
neilkevins neilkevins is offline
hi there...
Looked everywhere and I can't find the repair manual for my buddy's 2001 Protege' LX. Any help with locating this guide or a PDF (Which would rock!) would be nice.
Thanks in advance.
Old 11-18-2009, 08:52 PM
check the air hose from the air box to motor. if there are crack in the hose, the extra air really confuses your ECM , it can't set engines idle.
16, 2000, 2001, 626, air, clean, cleaning, control, electronic, iac, idle, manual, mazda, online, protege, repair, valve
