84 rx7 help
Old Feb 11, 2006 | 07:34 PM
84gsl24's Avatar
Default 84 rx7 help
i just got a 84 rx7 gsl and the L coil doesn't have power,is it supose to i just replaced it ? and when i take off the L1 and L2 plugs when running it doesn't effect the engine. is their a problem or is that normal. and it is hesitating when giving it gas, and doesn't seem like it has any power when driving is this related
Old Feb 11, 2006 | 08:20 PM
84gsl24's Avatar
Default RE: 84 rx7 help
and the L1 L2 plugs don't have any spark is thi normal plz someone help me
Old Feb 22, 2006 | 11:05 PM
No that is not normal to not have spark from the Leading coil. The Leading spark is the primary ignition source and Trailing is just a clean up spark due to the elongated shape of the combustion chamber. Both coils should have 12 volts to them at the Black w/ white stripe wire at all times the key is on. This is the 'positive side' of the coil. The other side should flash a test light during cranking and with engine running and is connected to the ignitors mounted on the side of the distributor.
perkinsbl
Aug 26, 2007 03:51 PM
84gsl24
Feb 11, 2006 07:19 PM
84gsl24
Feb 11, 2006 06:46 PM
localwave
Jan 17, 2006 01:13 AM
Dan4Dee
Jun 15, 2005 10:33 AM
