2001 Mazda Tribute DX A/C problem please help!
Old Jul 29, 2010 | 09:29 PM
wahoowa90's Avatar
Default 2001 Mazda Tribute DX A/C problem please help!
I'll probably end up having to take this to a professional but so far I've called a couple auto body shops and none have known what to tell me so I figured I'd post here. I just bought a used 2001 mazda tribute dx. Before I bought it the guy said he had to get the a/c fixed so he took it to a shop where the mechanic said that there was a leaking line so he replaced all the rings and it was good to go. The guy sold me the car and the a/c seemed to work great as I was going home and going around town that day at slow speeds. However, when I got onto the highway or went above 45 mph for more than 5 minutes the a/c quickly disappeared until it was non existent. Once again, I came to a red light and when the vehicle was stopped after about a minute the A/c was ice cold again but the second I was above 45 mph for a couple minutes it quickly disappeared. Any idea what could be wrong? Please let me know! all suggestions and ideas are welcome
Old Aug 8, 2010 | 01:04 PM
ric325's Avatar
Default Re: 2001 Mazda Tribute DX A/C problem please help!
Does anything else fail along with the a/c under the conditions you describe? Headlights / dash panel dim on you, windows are sluggish going up and down, radio failing etc. I had an alternator that was overcharging the battery and causing electrical problems such as this until it would "cool down", only to return again.
Old Aug 9, 2010 | 07:14 AM
sean123tribute's Avatar
Default same happens to our tribute
Hi,
Funny you describe our problem. At low speeds, it take s awhile, but the a/c works....when you go highway speeds, it does not.
I;ve thought about recharging it with a kit, however I cannot locate the low pressure service port to connect the gas to....any ideas where the ports are located? Which is high and which is low?
awatebhu
Apr 9, 2020 08:32 AM
gerco
Jan 1, 2018 03:49 PM
byrdman73
Aug 4, 2011 11:46 AM
CTTribe
Aug 8, 2010 12:41 PM
Simonbm
Oct 22, 2007 07:45 PM
