No power to fuel pump
Old Jan 12, 2005 | 05:52 PM
ruidasilva's Avatar
Default No power to fuel pump
Hello:
I have a 1992 MAZDA MPV V6 3L
My car began stalling gradually over 1 day and now it does not start.
I verified after and before the fuel filter that it is fuel starvation before and now no fuel at all.
I have remove the fuel pump and verified that is working.
I checked the main fuse and it is good.
I did all the tests on the relay including continuancy and voltage and it passed except for two of the wires I get 9 volts versus 12 like the book says. I don’t think that is the reason for my problem.
I verified that I don’t get any voltage at all at the fuel pump connection.
I believe that the problem is from the relay to the connector.
I have not checked under the car for broken wires but I will next.
Is there anything else between the relay to the fuel pump connector that may be causing this problem?
Could it be that the difference in voltage of 9 and 12 on two of the wires of the relay may be causing this problem? If this was the case I should be getting the same 9 volts on the fuel pump connector but I get nothing.
Any ideas would be appreciated.
Thanks Rui
Old Mar 17, 2005 | 12:52 PM
sandee's Avatar
Default RE: No power to fuel pump
i have a 90 mpv and i had to change my distributor but it still is sputtering and jerking and cutting off someone told me to check the mapping sensor but i cant seem to find it.. have u gotten ur van fixed
imurphy
Sep 4, 2010 12:02 PM
dalek
Apr 6, 2009 12:29 PM
duckman_54773
Oct 18, 2007 02:56 AM
Variety=Spice
Oct 11, 2007 11:14 PM
chetcpo
Feb 19, 2007 03:27 PM
