Injector Problem - I think
Old Feb 26, 2005 | 06:01 PM
DLMiner's Avatar
Default Injector Problem - I think
Ok, I replaced the engine in my car as we discovered there was no saving the other one, sort of a lost cause when the rod is sticking out the side of the block.
Anyways, I bought a new engine and installed it, however the injectors won't open. If you squirt fuel into the intake where the throttle positioner is, it will run until the fuel is exhausted. We've got plenty of fuel pressure from the fuel pump about 70-75psi, and the sensors are all good.
I am at a loss here as to what the problem is. Chiltons is no help at this point because there is no explaination in the book as to what to do when you are pulling your hair out.
De
Old Feb 26, 2005 | 10:05 PM
MAZDASERVICE's Avatar
Default RE: Injector Problem - I think
First I would check Power at your injectors...if that isnt the problem Then i would have to say the PCM requires a "reflash" or replacement. Hope this helps.
luce az
Apr 10, 2010 09:10 PM
chriscisme
May 29, 2007 09:11 PM
john2568
Feb 21, 2007 06:17 PM
bigzoom
May 22, 2006 01:18 PM
jeff1202
Jun 27, 2005 08:01 AM
