Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
intakes and carbs?
Old Mar 29, 2005 | 04:50 PM
nross001's Avatar
Default intakes and carbs?
I know weber makes a bad *** looking two barrel perf. carb. but does any one make an perf. intake for the 2.0 b-series.
[IMG]local://upfiles/595/D518592BC72B4A32A75F5CA13C56DB11.jpg[/IMG]
Old May 31, 2005 | 01:14 AM
bdmazda's Avatar
Default RE: intakes and carbs?
not really much you can do with a intake if your intentions are to body drop the truck, there is not any room under the hood to use a perf intake. I actually have a weber .380 with a k&n 4" tall airfilter and had to cut the hood to allow for the clearance. and the very top of the carb is clean and flush with the hood and all 4 inches of air filter stick through the hood. hope that helps. just stick with the weber. it is awesome and actually gets better gas mileage than the stock carb.
Old Jul 9, 2005 | 11:40 PM
Kyrasis6's Avatar
I only know of two places that make a performance manifold for the B2200 and B2000, unfortunatly there are a few catches to them. The first is both companies are in Africa, the second is although I think they are $60 and $80 USD I think they are both for delereto (sp?) setups. The last time I looked a used carb setup would run $800 and a good one would be well over $1200.
I soon hope to be able to custom make aluminum manifolds for the B2200 and 2000 and can currently make modifications that can add a few hp and gas mileage depending on your setup.
pemerkel2
Apr 14, 2008 05:25 AM
mph
Mar 24, 2008 12:05 PM
Fevered
Feb 14, 2008 02:54 PM
eflores
Jun 8, 2006 09:09 PM
ULoSe
Jun 14, 2005 03:18 PM
