Clutch Judder
Old Apr 1, 2005 | 03:48 PM
beano's Avatar
Default Clutch Judder
Letting a great car down! Has anyone had any prob with clutch judder, especially first couple of miles when cold. Mazda dealer checked twice for fault but found no problem. I know of one other owner with same problem, he has had the same response from a different dealer.
Old Apr 1, 2005 | 06:07 PM
MAZDASERVICE's Avatar
Default RE: Clutch Judder
I HAVENT HEARD OF THIS ISSUE ON "ANY" MAZDA 6 MODELS BUT THERE IS ALWAYS A CHANCE THERE IS A PROBLEM ...WITH THAT SAID
-MAKE SURE VEHICLE IS AT 100% OPERATING TEMP....THE TCM WILL NOT RESPOND THE GREATEST IF ITS REALLY COLD.
-HAVE THE DEALER CHECK FOR PCM AND TCM UPDATE-THERE MAY BE SOME UPDATED DRIVERS YOUR VEHICLE NEEDS.
HOPE THIS HELPS
Old Apr 1, 2005 | 07:09 PM
I JUST FOUND OUT -THAT IF THIS IS A 4 CYLINDER MAZDA 6 -YOU HAVE TO BE ABOVE 2000 RPM OR MORE-OR IT WILL JUDDER
THIS MAY HELP
Old May 12, 2005 | 09:32 PM
exiledtiger's Avatar
Also have the cold clutch judder problem.Shouldn't have to rev an engine that high to get started. Suspect a design flaw rather than a mechanical problem. If enough of us complain, they might come out with a fix.
Great car other than that and the squeaky brake thing. It does love the open highway, doesn't it!
Old May 26, 2005 | 01:11 PM
2004mazda6gfx's Avatar
Got the same trouble with my V6, even with a short shifter on. And found this a real pain in the daily driving and not fun to shift up or down.
Often I think I should had choose the automatic instead to get a more steady and smooth gearshift.
I am trying to see how to fix it, or at least how to get a smoother shifting, and I let you know.
Mazdaservice, have you any complaint on this from other 6 owners?
Old Jun 12, 2005 | 07:43 PM
Thank you. I shall get back later on with Mazda concerns.
9000se
Dec 14, 2013 06:50 AM
kippax61
May 17, 2010 07:03 PM
lewis323
Jan 27, 2009 08:47 PM
Grajan
Oct 29, 2008 09:19 AM
gtxtreme
May 31, 2005 03:02 PM
