Electrical Shortage
Old Jun 3, 2005 | 06:33 PM
88RX7's Avatar
Default Electrical Shortage
Shortage in electrical system. Door Locks/ windows...... drain the battery.....
Old Jun 4, 2005 | 12:42 PM
Old62's Avatar
Default RE: Electrical Shortage
Are you asking a specific question or making a statement?
Old Jun 10, 2005 | 10:25 PM
YOU NEED TO CHECK THE WIRE HARNESS GOING TO THE DOORS. EVERY TIME THE DOOR IS USED THESE WIRES ARE BENDING. ALSO LOOK AT
THE CONDITION OF THE RUBBER/PLASTIC GROMMETS AROUND THE HARNESS OUT OF BODY AND INTO THE DOOR.
THERE SEVERAL WAYS OF CHECKING DARK CURRENT DRAW; ONE IS WITH AMMETER, THE OTHER LIGHTED CIRCUIT TESTER. FIRST MAKE SURE
EVERYTHING IS TURNED OFF, KEY OUT OF SWITCH AND ALL DOORS CLOSED. FOR YOUR SAFETY, USE A RAG TO COVER POS BATTERY POST
WHEN DISCONNECT THE NEG CABLE, CONNECT TESTER IN SERIES. IF TESTER LIGHTS THERE IS A DRAW, GO TO THE FUSE BOX UNDER HOOD
AND REMOVE ONE FUSE AT TIME WHEN THE LIGHT GO OUT YOU HAVE FOUND THE PROBLEM CIRCUIT POWER SOURCE.
AT THIS TIME A WIRING DIAGRAM COME IN HANDY, TO TRACE THE CIRCUIT ROUTE.
mtnmazda
Mar 21, 2016 10:56 PM
jamiesaur
Aug 8, 2009 05:51 AM
meana0526
Jul 10, 2006 11:31 PM
Oddball
Jan 7, 2006 02:43 AM
jeff1202
Apr 12, 2005 12:08 AM
