Mudflaps don't work
Old Nov 15, 2006 | 10:27 PM
altaski's Avatar
Default Mudflaps don't work
I put the factory mudflaps on to make sure I protected the paint on the doors from chips. Well, last weekend we had our first snow and they put cinders on the road. I drove 20 miles in it. Now the paint at the bottom of the doors is so peppered with paint chips it looks frosted white. In only 20 miles! My toyota supra wouldn't have that many in 10 years, nor would my Magnum, or any other car I've ever had. I'm going to get this covered under warranty eventhough it does not cover stone chips. The intent of the warranty is for a reasonanble amount of chips over a period of time. This is Extremely excessive which wuld be classified as a defect in either fender, door, or mudflap design. So if you want to save your paint and not go through this, add some big extenders to those front mudflaps!
Old Jan 24, 2007 | 11:35 PM
Alpha Wolf's Avatar
Default RE: Mudflaps don't work
Could you post some pictures of the damage??
Any luck getting the repair covered?
Old Jul 23, 2007 | 01:14 PM
altaski's Avatar
Mazda warrantied a repaint of the bottom portion of doors. Looks as good as new! Put on clear gaurd and big mud flaps. will post pics soon.
Old Jul 23, 2007 | 01:29 PM
Alpha Wolf's Avatar
Do you have any pics of the damage?
The rear flap looks large enough to work. But the front ones are only marginally larger than stock and yes I an see that it would not stop a lot of gravel etc...
Old Sep 10, 2007 | 11:02 PM
Soapmech's Avatar
I agree with the bad front mudflap design. We have around 2500 miles on ours, and we already have 2 good size stone chips on the drivers side. It's almost as if the lower door paint is too brittle.
Old Sep 11, 2007 | 03:26 PM
Alpha Wolf's Avatar
Yes the rear ones are sufficiently large to actually do some good
The front are barely larger than stock and offer no better protection. I guess they thought larger ones would look bad.
But how bad do rock chips look?
So I avoid rocky roads or I go extremely slow. If I must go some where there are gravel/dirt roads I take our Turbo Baja and its mud flaps work.
Old Sep 20, 2007 | 10:51 PM
altaski's Avatar
Default Pictures of Mudflaps and Clear gaurd
I've got pics now but can't figure out how to post them???
Old Sep 21, 2007 | 09:55 AM
sstlaure's Avatar
Default RE: Pictures of Mudflaps and Clear gaurd
Click "Post Reply", then under the text box click "Click here to upload", attach your .jpg files, Click on "Embed picture in post", then click "OK"
The pics you attach should show up in your post.
Old Sep 21, 2007 | 10:52 AM
altaski's Avatar
Pics
Old Sep 21, 2007 | 11:03 AM
altaski's Avatar
pic
