Fuel Injector leaking
Old Jun 11, 2005 | 09:01 PM
jeff1202's Avatar
Default Fuel Injector leaking
Recently replaced the fuel injectors on my '84 GSL-SE. I can't stop them from leaking where they plug into the fuel rail. Any suggestions?
Old Jun 23, 2005 | 10:45 PM
Default RE: Fuel Injector leaking
Did you also replace the o-rings on top of the injectors, and if so where they the right size o-rings? How about the bottom seals, are they new, was there any spacers? If the rail can't pull down on the injectors for tight fit, are the injectors the right length? Should be able to twist the injector but not more up and down.
Old Jun 27, 2005 | 08:01 AM
Old62's Avatar
you probably shouldn't drive it untill you get it sorted out
TurboC
Jun 25, 2008 05:17 PM
mzd3_stratblu
Oct 13, 2007 07:54 PM
travisgarrison
Aug 27, 2007 01:54 PM
john2568
Feb 21, 2007 06:17 PM
bigzoom
May 22, 2006 01:18 PM
