Old 11-26-2006, 12:31 AM
tbaracani tbaracani is offline
Default Heater
Hi,
I bought my 95 mazda Millenia for $1900 which is an excellent deal, the only problems we have had are that the car at first would not accelerate my trusty shade tree mechanic fixed that problem by adjusting the idle. Well now the only real issue I have with my Mil is no heat! The ac works like a dream however, when turned to the hot no hot air only cold, ICE cold! Any one have any ideas?
Old 12-10-2006, 02:38 PM
spdracer7 spdracer7 is offline
Default RE: Heater
I experienced the same problem a few weeks ago in my 98 millenia. It was colder than normal outside and on my way home from work I never could get it to blow warm air. It hasn't happened since then and I hope it never does, but the reason I'm replying to your post is that I had a similar problem with an 88 celica that I used to own. It seems that the wiring in the controls can work its way loose or possibly the temp change outside can affect the contact on the wires. In my celica, it seemed that the "default" was for the warm air to be closed off and the controls made it open to let it through. I came across another button panel at a junkyard for $5 and it fixed the problem. All I had to do was unplug the old one and replace it with the new one (after removing half the dash to get to it). I believe this is the same issue in the millenia. When you adjust the controls you should be able to hear some parts moving behind the dash (quitely). The day mine wasn't working I couldn't hear anything.
Old 12-31-2008, 04:46 PM
ikennygu ikennygu is offline
Default RE: Heater
I have a 2000 millenia and I had the same problem. I downloaded the repair manual for a 96 millenia, which is not exactly like the 2000 but here the site "http://rapidshare.com/files/51248650/Millenia-1996.rar". We took the radio out to see what we could find and at the same time my friend was reading over some things I had printed off. Come to find out it was the c/c computer needed to be reset. In order to do that you can find that on Pages U22-U26 of the manual. It was either that or it might have been where we took the negitive cable off the battery for about 2 minutes either way I have heat now without taking the dash out. If you can't download the manual let me know and I look at it again and explain it to you. Good Luck!
ikennygu
Old 11-06-2009, 11:09 PM
r4ladyeyes r4ladyeyes is offline
Smile
I have a 98 Millenia and every winter I have no heat. I have ac great all summer and when I switch it back to heat during the weather change the heat does not work. I have found that the door does not shut to allow the hot air to circulate into the cab due to lint obstructing the arm from moving. I found that the arm frees easily with a squirt of wd-40...has worked everytime for me and saved me the cost of taking it into the shop for a mechanic to repair.
r4ladyeyes
heat, mazda, millenia
