My car is swirving
Old Jun 13, 2005 | 12:27 AM
94MazdaPro's Avatar
Default My car is swirving
If anyone could help ide appreciate it. Im having a problem with my car, it swirves side to side when i go at a rate of speed of (65-80) and i currently had my R/F axel changed, R/R bearing, and they told me that i shouuld have my lower ball joints also changed. So when they repaired everything they said it shouldnt be moving the way it was, but still continues. Im assuming that it could be one of two things: Rack & Pinion, or my Control Arm Bushings. Maybe i need an alignment also (not done yet).
If anyone could help me ide glady appreciate it.
Thank You
Jerome
Old Jun 13, 2005 | 08:37 PM
bdmazda's Avatar
Default RE: My car is swirving
go for the alignment and the bushings, great improvements would be noticed, and also have the shocks and struts checked while you are at it. those can cause quite a bit of pitch or roll in a car when they are worn and need replacing.
Old Jun 23, 2005 | 12:48 AM
UDBassist87's Avatar
I had the same problem with my 86 323. come to find out it was a broken band in one of my front tires. that might or might not be your problem but hey at least i tryed.
turborx
Dec 16, 2007 07:00 AM
