general rx7 knowledge...
Old Jun 20, 2005 | 04:10 PM
purpleham's Avatar
Default general rx7 knowledge...
hello all,
im still looking to buy an rx7 and strugling to find one i like..i was just wandering a few thing i should look out for example(what oil pressure should it run at) engine noises how to test for low compresion any help would be much eblieghed..
thanks again,
Old Jun 21, 2005 | 09:01 PM
Default RE: general rx7 knowledge...
Few things to keep in mind; hard starting both cold & hot, weak engine. How much & how long does it smoke after starting, worn oil
seals if blue smoke. White smoke with biter/sweet smell, internal coolant leak. Compression tests to get the most accurate results
have a dealer test. You can use a conventional tester, but have to remove the schrader valve from the end of hose. It takes two
one cranking and one watching the gauge. You need a cranking rpm of at least 250, then you want all the reading to be very close.
The dealer has a special tester with a ditigal display for rpm and each side of the rotor. Readings in the 7 range are good.
Engine noises you should have any. Avoid automatics, not much performance. Proper cooling is another issue, especially with
third generation rx's. One last note, as alway when buying used, take it to a mechanic you know or service center you do business
with and have the car up on hoist. There some real crappy rebuilders out and about. It's worth 20-25 bucks to have the underside
inspected, that includes dealers cars.
Old Feb 21, 2006 | 02:25 AM
PappaSmurf's Avatar
can someone tell me please where is the crank angle sensor located? I am new to the whole mazda family but recently bought a 1987 rx-7 but having trouble starting during cold weather. the spark plugs and wires, altenator, and battery are brand new and i wanna get this car running and starting with no problems what so ever so that i can continue to add to it. thanks for any help whatsoever.
-Smurf-
early626
Apr 1, 2006 05:58 PM
2blue
Mar 30, 2006 05:18 PM
moonlight
Mar 15, 2006 10:06 PM
Nando 6i
Jan 18, 2006 03:39 PM
gsxrsrad1000
10
Dec 21, 2005 04:28 AM
