Engine light @ flashing "hold";new owner!!!
Old Jun 22, 2005 | 04:10 AM
mazdaphile's Avatar
Default Engine light @ flashing "hold";new owner!!!
So I just got plates for my 97 millenia with 98,000 miles and today on startup the check engine light comes on and a flashing "hold" light comes on.....I have only been driving this car for two weeks. Question: am I screwed? it is worthwhile to figure out this problem on my own or should I go to the dealer? Are independent Mazda techs usually cheaper? Also the owner's manual says not to drive the car when the flashing "hold" light goes on....so do I have it towed somewhere? As you can see I am a newbie with this car. According to other internet comments, it is a faulty transmission others say a speed sensor............if you know anything tell me what you would do if this was your car................thanks for your help
Old Jun 22, 2005 | 02:55 PM
danijel's Avatar
Default RE: Engine light @ flashing "hold";new owner!!!
Hey, my light check engine is always on, but it's running ok, they say thats a problem with sensor, no big deal, but HOLD, dunno??
Mazda dealer will rip u off, thay r 2 expensive, so try somewhere else!!
See ya
Old Jun 22, 2005 | 09:03 PM
Most service center charge a diagnosis fee, for connecting a scanner to pull codes. Call around find the cheapest place. You can
ask for an estimate to repair, but you don't have, to have them fit it. As for the MIL & HOLD lights, best pop the hood, do the basic
checks, like is the ATF fluid low, etc. If everythings seems ok, drive it, to have it checked ASAP. Post the codes and which model
you have. I'm sure we'll be able to help.
Old Jun 23, 2005 | 08:07 PM
mazdaphile's Avatar
Okay, sounds good...I will do a quick atf check and fuses...it is a Millenia S 1997...for future reference....
if this doesn't pan out...should I still drive it with the "hold" light flashing? can Autozone read codes for this car?
I love this car so should I invest in a code reader anyway? And I will try and get a fac. shop manual too....thanks for the tips I'll get back to y'all when I have more info.
Old Jun 23, 2005 | 09:35 PM
Yes, Autozone should be able to scan codes, however depending on the code, they might not have the info for it.
Just drive when you have to, until you get the code number when we can determine if driving will do more damage.
Old Jul 8, 2005 | 12:55 PM
HecKler's Avatar
I had the same problem. Hold light flashing. It was a trany speed sensor... ran about 120.00 bucks,
dealer item.
Kazel
Oct 31, 2008 04:36 AM
Razdude
Oct 31, 2007 04:37 AM
rooster2
Jun 22, 2007 06:30 AM
mph
Apr 2, 2006 04:31 AM
Eric
Mar 28, 2006 03:18 PM
