Old 02-12-2007, 08:25 AM
Tracker's Avatar
Tracker Tracker is offline
Default Most FAQ's for this section
This thread is to help answer those questions that have been asked so many times that its engraved into our memories and have bad dreams about them.
P.S: If anybody has something to add or correct anything please just pm me with the q&a, all replys will be deleted, as for mods feel free to edit this post to add/change anything.
__________________________________________________ _______________________________
Q: Which Intake is the best?
A: Intake is a intake is a intake, theres not much difference between any just make sure if u decide to buy one from ebay that its the correct one i.e. the MAS port is in the right spot and it has a breather port.
Q: What does CAI stand for?
A: Cold Air Intake
Q: Does adding a intake and or exhaust void my warrenty if its not mazdaspeed?
A: Only if something major happens and it caused by the intake or exhaust, i.e seizing due to water intake, or emission failure from cel.
Q: Do parts for the 2.3l engine fit the 2.0l?
A: All of the outside dimensions are the same its the internals that are different and a couple of misc sensors, the only thing interchangeable w/o any modification is the head.
Q: Can i tune my ecu?
A: No mazda said "were not gonna make this easy if your american", but i can tune via standalone FMU's
Q: Which turbo kits are available?
A: Hiboost, F2, and tripoint
Q: Is it cheaper to make a custom kit or just buy one?
A: Although it MIGHT be cheaper for the parts themself, u will be paying out the ass if you plan letting a shop make on for you plus countless days without your car, not even mentioning that its a lot riskier.
Q: When does the speed governor kick in and how do i get rid of it?
A: The limiter kicks in exactly 118mph, there is only one known way of getting rid of it is by getting the stand alone fuel computer.
Q: Is it really worth getting the Hiboost kit?
A: Dunno...is it really worth living?
Q: Which is safer to turbo 2.0 or 2.3?
A: 2.3 has lower compression ratio and will also give you more power per psi vs the 2.0, safe boosting lvl on stock block is 8
Q: Is it illegal to put on any performace parts?
A: To put it simple its like this....when it comes to performance if it dont come from factory its ILLEGAL, it depends which cop pulls you over.
Q: Whats the difference between the models between 04 and 09?
A: The differences are that most problems with the 04 were fixed in the 05, the 07+ just have different body dimensions in the front and rear bumper and wheels, but have the same bolt pattern if you wanna throw on a bodykit, oh and the 07+ have a extra cat convertor after the exhaust mani, so intead of 2 (as if that werent bad enough) they have 3.
Q: Can i turbo my autotradic?
A: You kno....i should just tell you no, but u can, but its alot more crap 2 deal with....get a 5spd u lazy mofo.
__________________________________________________ ________________________________
Q: How come my 04 did this or that?
A: What part of all 1st gen 1st year car car did you not get? ALL 1st anything will have defects, your car, your xbox, your 1st gf etc
__________________________________________________ _________________________________
Q: Do i need to replace my goodyears?
A: Umm hell yes, they are the most overrated (next to perelli) pos rubber to ever hit the road. If they made a condom it would break before you opened it up. simple goodyear=HARDCORE FAIL.
Q: Does this part from this year fit my car from this year?
A: Yes all parts fit from 04-08 the ONLY difference is that the 04 05 and 06 have different sources from where they get there rpm signal but 06+ have the same rpm signal.
Q: Will parts from the Speed 3 fit my non spd?
A: Anything from the outside will mount correctly i.e. ic piping, turbomani, NOTHING internally will work the spd 3 has completely diff specs on the inside, yea i kno it sux :s
All of my statements/comments are based purely on fact
~The Critic
dimensions, f2, hiboost, intake, speed3, stock, turbos
