Trunk won't open...
Old Jul 19, 2005 | 11:13 AM
kccollier's Avatar
Default Trunk won't open...
Hey everyone, I am new to this forum and have a question for you. I have a 2003 6 that was bought new. It has just under 50,000 miles on it now, but all of a sudden, the remote trunk release and button on the dash will not open the trunk. You press the buttons and it does not do anything. I was busy at the time and blew it off, using the key to "pop" the trunk. Now, a few days later, the key doesn't even pop the trunk. This is so strange and I have absolutely no idea why this is happening. Anyone out there with a fix?
Old Jul 19, 2005 | 10:20 PM
Default RE: Trunk won't open...
It's possible for the electric solenoid to come apart. There's a threaded rod that goes thru it, can work it way out then it won't open.
You may be able to repair, the one I had put it back together and ordered new one, of course it was under wty. Becareful when removing the plastic stuff.
Old Jul 22, 2005 | 11:51 AM
Fragile's Avatar
yoeah, something is broken, go to a dealership and have them take a look
Old Jul 29, 2005 | 09:30 PM
First thing to check is to make sure the valet lockout button is not turned on. The button is in the glovebox in the upper left corner. This disables use of the inside release button and remote operation. Also make sure that you are not using the valet key as it will not open the trunk or glovebox lock. If all those are ok a trip to the dealer should be in order.
Old Oct 28, 2013 | 07:02 PM
harrisonkats's Avatar
Smile Trunk won't open...
thank you babyhuey it worked
Old Jan 6, 2017 | 09:57 AM
Trotboy's Avatar
Default Our solution
Ours is a 2005 saloon and it doesn't have a button below the steering wheel, or an isolator in th glove compartment. However, I found that the solution is that the release handle is stiff and gets stuck in the 'forward' position - it doesn't return to the default position. So when you try and open it it doesn't release. The solution is to push the back of the handle back in towards the boot as far as it will travel. Then lock the car, and unlock it, then it will open. Because the handle is still stiff (I will try some WD40 on it and see if it frees up a bit) I have found that moving it back into position when the boot is open means it will function properly for the next cycle of locking and unlocking. Hope this helps someone else.
Old Mar 20, 2018 | 07:10 AM
Pinzgauer's Avatar
Hi. First post. Just joined in order to say a big thank you to Trotboy. I've a Mazda 2 Capella. Tailgate/boot lid wouldn't open. No amount of dubious words seemed to make any difference ! Tried pushing the release handle back as suggested. Locked and unlocked on key fob. Bingo - it released. Took boot lid trim off and treated everything that moved with WD-40. Phew ! This could be a very handy site. Thanks again.
bpeterson407
Nov 13, 2013 04:29 AM
arnie59
Nov 17, 2010 07:30 AM
TA/Hawk
Dec 30, 2009 04:41 PM
pattyd814
Jun 27, 2009 08:35 AM
ichimazda6
Jan 31, 2009 09:27 PM
