Rear Brake Problem
Old Jul 19, 2005 | 03:22 PM
mainman2c's Avatar
Default Rear Brake Problem
Hello, I am new to this forum and I would like to introduce myself, my name is Roubel I am from the DC area and I don’t really have to much mechanical experience. I work in the tech field so I am good at learning to fix things on my own. The problem that I am having is I have a 1997 Mazda 626 4 cylinder automatic and I noticed that my brake lights would come on. I then checked my pads and everything could not find any issues, then I noticed my brake fluids were low I refilled then a month later I noticed it go low again. I finally noticed that my left rear tire had oil on it and it was leaking from the rear brakes. Has anyone else had this same issue occur ? I am trying to see if I can find a diagram for the rear brake assembly so I can replace the whole assembly with a more mechanically inclined friend. Any help or suggestions would be appreaciated.
Old Jul 19, 2005 | 09:17 PM
Default RE: Rear Brake Problem
Get a can of brake cleaner, jack up, remove wheel, clean the area. Have a friend depress the brake a few times, see if the brake
hose is leaking, may have just a loose connection to wheel cylinder. If you decide to do the repair, check the book store for repair
manual, usually under $20, plus then you have info on the whole car.
Old Jul 21, 2005 | 02:19 AM
blueman's Avatar
Prior advice excellent. Only would add as a direction to go is keep in mind car may be ready for rear caliper if it has drum brakes not pads & disc on rear.
kgzak
Aug 7, 2015 12:23 PM
49er
Jun 17, 2015 04:13 PM
schlompie
Mar 6, 2012 02:49 PM
jafo104
Jul 18, 2008 04:55 PM
mtarajia
May 15, 2007 02:24 PM
