Timing Belt replacement 91 1.6 DOHV
Old Jul 20, 2005 | 06:22 PM
russmazda's Avatar
Default Timing Belt replacement 91 1.6 DOHV
i recently broke the timing belt will I have to remove the head for valve replacemnt, is this a clearance valve engine? thanks
Old Jul 20, 2005 | 10:07 PM
Default RE: Timing Belt replacement 91 1.6 DOHV
All mazda engines with timing belts are clearance or free spinning, unless you were cranking 9grand when it broke.
When you replace the timing belt be sure to inspect the crankshaft gear, key & shaft for wear.
kinni420
Jan 28, 2013 03:08 AM
mazda99
Aug 13, 2008 04:18 AM
homeflash
Apr 4, 2008 11:55 AM
becca31
Feb 17, 2006 08:24 PM
