Starting issues again...
Old Jul 26, 2005 | 05:42 AM
superloudrx7's Avatar
Default Starting issues again...
I have an 87 non turbo that won't start. The fuel pump isn't getting any fuel and the coils will produce no spark. I've changed the coils and igniters the fuel pump, the fuel pressure regulator and the ecu. I've also changed my plugs and wires and every fuse and relay I could find. Any one ever have this problem before?
I'm assuming my problem originates somewhere in the electrical department, but I don't know where else to look. I'm pulling my hair out on this one...
Old Aug 16, 2005 | 03:28 AM
mR.dnA's Avatar
Default RE: Starting issues again...
Check the crank angle sensor.
If it's not working, the ECU won't know that the engine is actually cranking, and thus won't fire up the fuel pump or coils.
Old Aug 16, 2005 | 11:56 AM
Patrick's Avatar
Administrator
i have seen similar problems with Lots of different cars due to ba dcrank sensors.
Old Aug 18, 2005 | 09:41 AM
Old62's Avatar
have you checked for fuel in the tank?
the engine will not run, or start (in your case) without fuel. get this problem sorted out first. how do you know the fuel pump isn't getting any fuel. did you remove the filter and no fuel came out?
how do you know that there is no spark from the coils, are you earthing it to the engine when trying to turn it over.
KSmk
Dec 20, 2008 11:10 PM
rnewby22
Jul 27, 2007 10:54 AM
sc0rpi0n
Apr 15, 2007 03:13 AM
csxfbird
Oct 12, 2005 10:02 PM
superloudrx7
Jul 9, 2005 10:34 PM
