Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Lift the rear
Old May 5, 2007 | 12:41 PM
wv626's Avatar
Default Lift the rear
I just bought some 18 in wheels off my buddyfor my 99 626. The rear is scrubbing pretty good the size of the tires are 245/40.I was wondering what can i do to eliminate the problem. I am open to all suggestions.
Old May 5, 2007 | 04:40 PM
Default RE: Lift the rear
245/40's? Man, those are pretty big for a 626 aren't they? They'd be impossible on a 3, especially a lowered 3.
'Sounds likesome fender rolling is in order if you are planning to keep it that way. Or get smaller tires... I don't know what the stock tire size is on a '99 626, but say 215/45's? You may not have any other choice.
You don't want to lift the rear of a FWD car. That'll throw it way out of balance. Most of the weight is already on the front. (+/-60%)
You may be losing more in unsprung weight and rolling resistance (friction) than you're gaining in handling w/that set up. Your mileage (mpg) is liable to go down too.
Old May 5, 2007 | 07:49 PM
wv626's Avatar
Well they aren't rubbing the finder. Actually they fit under nicely. They are scrubbing the bottom of the strut. All i need is about .50-.75 lift.
Old May 6, 2007 | 01:33 AM
Perhaps wheel spacers would do the job then, though I'm not too crazy sbout that idea myself?
I think if I had to choose the fix, I would simply put on narrower tires, or wheels if that's the case. Anything else is just like putting a Band-Aid on it and is a compromise to cover up the real problem.
Old May 6, 2007 | 10:10 PM
wsoape281's Avatar
i would just get a lower control arm that had adjustable camber. then you could adjust the upper and step it out a little. who knows, the lower control arm might bring it out a little by itself.
Chaney
Sep 23, 2013 02:19 PM
Chaney
Nov 16, 2010 08:13 AM
07_CX9_grey
Jun 1, 2007 07:22 PM
blasphemous
Apr 19, 2007 03:34 AM
Warrior
Jul 29, 2006 02:38 AM
