cx9 alignment specs
Old May 7, 2007 | 01:09 PM
john k's Avatar
Default cx9 alignment specs
My new CX-9 pulls to the left a little. How do I get the alignment specs on this vehicle.
It is a Touring model with 18" wheels.
Thanks,
JK
Old May 9, 2007 | 10:06 PM
mazda1106's Avatar
Default RE: cx9 alignment specs
TSB: 02-003/07
2007 CX-9 - STEERING PULL / DRIFT
APPLICABLE MODEL(S)/VINS
2007 CX-9
DESCRIPTION
Some customers may complain that the vehicle pulls to the left or right during normal driving conditions.
Customers having this concern should have their vehicle repaired using the following repair procedure.
REPAIR PROCEDURE
1. Test drive vehicle and verify customer concern.
2. Confirm pull/drift is not caused by the following factors:
Road crown or wheel track during constant speed driving.
Different size tires or uneven tire wear between left and right tires.
Brake drag on any wheel.
Excessive ball joint clearance or steering linkage play.
3. Check tire pressure. Front and Rear Cold Tire Specification = 36 psi (18-inch tire), 34 psi (20-inch tire)
If tire pressure is too low or too high, correct tire pressure as necessary and test drive vehicle again.
If vehicle no longer pulls/drifts, return vehicle to customer and explain the importance of proper tire inflation to the customer.
If vehicle pulls/drifts, go to next step.
If tire pressure is correct, go to next step.
4. Swap left and right front wheels/tires and check for damage or deformation of control arms, brackets, or bushings. If any item is damaged or deformed, repair as necessary. Test drive vehicle.
If vehicle no longer pulls, return vehicle to customer or dealer inventory.
If no improvement is noticed and vehicle still pulls or drifts, go to next step.
5. Confirm position of left and right strut mounting rubber identification marks. Identification marks should be positioned as shown.
Remove the left-side windshield wiper arm.
Partially pull back the cowl grill.
6. Check wheel alignment of the vehicle. Refer to ALIGNMENT SPECIFICATION CHARTS for 2WD or 4WD vehicle.
7. Confirm the direction of vehicle pulling (left or right) and adjust camber and caster angles at the same time.
8. Adjust the strut mounting rubber as follows:
Jack up front of vehicle and support on safety stands.
Remove mounting rubber nuts.
Push shock absorber and coil spring assembly downward, and turn identification mark to desired position.
Adjustment Value From Original Position
Identification Mark Position
Camber Angle
Caster Angle
A
0°
-0° 22'
B
+0° 22'
-0° 22'
C
+0° 22'
0°
NOTE:
If the vehicle pulls right, rotate the left side strut mounting rubber 180 degrees so the position of the "identification mark" is inside the circle. (Position B)
If the vehicle pulls left, rotate the right side strut mounting rubber 180 degrees so the position of the "identification mark" is inside the circle. (Position B)
After adjustment of mounting rubber, install components in reverse order of removal.
Tighten mounting rubber nuts to specified torque.
Tighten Torque: 34.1 - 46.2 ft.lb (46.1 - 62.7 N.m)
9. Adjust front toe to center of the specification as much as possible. Confirm all the other wheel alignment items are within specification. Test drive vehicle to verify the repair.
10. If the vehicle starts pulling/drifting to the other side, rotate the front strut mounting rubber back from Position B to C, by 90 degrees.
11. Test drive and verify repair.
NOTE: To convert "minutes" to "degrees", divide by 60. Example: 27' divided by 60 = 0.45°
cpouliot
Feb 16, 2010 05:29 PM
etacman
Apr 12, 2007 04:54 PM
etacman
Apr 11, 2007 01:35 PM
3rdMazda
Sep 3, 2006 06:37 PM
TINALEIGH33
Sep 30, 2005 10:35 PM
