torque specs and oil pan question
Old Aug 3, 2005 | 05:53 PM
g96818's Avatar
Default torque specs and oil pan question
can someone pls give me the torque specs for the nuts/bolts circled below?
thx and is there an online repair manuel floating around somewhere?
and can the oil pan be removed without yanking the engine out, cuz it's leaking a decent amount of oil. thx
edit: this is for a 97 model
Old Aug 7, 2005 | 08:53 PM
Default RE: torque specs and oil pan question
17 ft/lbs will cover all of the bolts listed. 14-19 is actual specs. Never pulled an oil pan on a 3.0l of that year. Sure it is not the front cam/crank seals? Leak from there should be visible at the lower sides of the timing covers. Have replaced more of these for oil leaks more than can shake a stick at. Somtimes looks like pan leak as the oil follows the gasket surface around the pan.
Old Aug 8, 2005 | 03:58 AM
g96818's Avatar
thx, do u have a pic of where i'm supposed to look for the cam seals? i'm still kinda new at this, locating stuff.
Old Aug 16, 2005 | 03:32 PM
Front cam seals will show leakage at the very front of the engine near the plastic timing covers. Look above the front crankshaft pulley on the sides of the engine. If oil is found above the oil pan line then you probably have front cam and-or crank seals leaking
Old Aug 18, 2005 | 04:14 PM
Had a 95 v6 in today with front seals leaking on right side. Will see if I can send picts for you. If two picts dont post them let me know how to do it as I never have.
Old Aug 18, 2005 | 04:22 PM
Lets try this again.
[IMG]local://upfiles/1377/EC1E71CE57BD4E2AB4AA19BBF1126A3C.jpg[/IMG]
[IMG]local://upfiles/1377/47DD2EFC969C4DE2AB1566754163B969.jpg[/IMG]
mig25
Jun 15, 2024 04:22 PM
mrich912
Sep 30, 2010 03:01 PM
scooter956x
Feb 2, 2009 11:48 PM
Dandj66
Mar 22, 2007 04:39 PM
6man
Jun 1, 2006 09:06 AM
