Help finding hard to find parts - Radiator support etc.
Old Aug 8, 2005 | 12:16 AM
mydogduster's Avatar
Default Help finding hard to find parts - Radiator support etc.
I'm trying to find vendors (other than the stealership) for frame related parts, i.e. radiator support etc. My wife managed to get the front end ripped off, and the forward most frame posts are bent, but the alignment isn't effected. I'm replacing the radiator, a/c condensor, hood, grill and bumper among other things. I've been looking online, but can't find the not so popular parts. Can anyone point me in the right direction? Any help would be appreciated! TIA
[IMG]local://upfiles/1488/D3F1D7D37FBF4C3DBDB6EB9A705E0396.jpg[/IMG]
Old Aug 8, 2005 | 04:13 AM
g96818's Avatar
Default RE: Help finding hard to find parts - Radiator support etc.
have u tried rockauto.com? if u search for the part, they have it, but i cant seem to find it in the listing. u should try calling them and asking for it
Old Aug 16, 2005 | 02:13 PM
roo's Avatar
roo
I can see how you might not want to pay this much for the front pieces...
LC11-53-100B (upper support, left and right panel shroud, lower crossmember and brackets) - $373.05
LB82-52-150B (lock stay) - $35.73
BV14-19-9S0 (blind cover for non-towing equipped MPV's) - $22.88
But then again, you're going to do an awful lot of searching for an MPV which doesn't have front end damage.
Old Sep 3, 2005 | 01:25 PM
Default Thanks a bunch, that definately helps....
the radiator it appears does 2 functions, one would be cooling the engine, however when I removed the old radiator, there are 2 lines on the bottom, and the fluid was different. Is it safe to think that it's auto-transmission fluid or something else? I'm not sure. thanks.
Old Sep 3, 2005 | 11:18 PM
Default RE: Thanks a bunch, that definately helps....
Yes it is automatic transmission fluid. Oil cooler for auto trans is part of the radiator. Virtually any aftermarket usually comes with oil cooler as part of replacement radiator.
Old Sep 5, 2005 | 12:42 PM
Default which trans fluid should I buy/specs?
I no longer have the owners manual to look at.
Old Sep 5, 2005 | 09:47 PM
Default RE: which trans fluid should I buy/specs?
Regular Mercon/Dexron III. Do not use Mercon 5.
Old Oct 19, 2005 | 12:00 AM
mazzfan's Avatar
i got some of my mazda parts at carpartswholesale.com, they offer a reasonable price.. try to check it and maybe you can ask for their assistance.
ZoomBoost
Dec 5, 2013 09:25 AM
Tucked FC
Apr 4, 2012 07:06 AM
sweetcoupe
Apr 20, 2010 09:40 AM
Blackout
Intake, Headers and Exhaust
10
Oct 10, 2007 01:52 PM
turbo_miata20
Jul 8, 2006 08:57 PM
