roll over switch?
Old Jun 16, 2007 | 09:33 PM
papalaw33's Avatar
Default roll over switch?
im working on an 87 rx7. i get no power to the fuel pump or starter. we have swaped ecu's to no prevail, and hooked the two problems strait to the battery so we know there not bad. is there a rollover switch? has anybody had this problem before? fixed it? any help would be greatly appreciated. thank you.
Old Aug 27, 2007 | 12:47 PM
hixx's Avatar
Default RE: roll over switch?
I would start at the ignition switch. Also drivers side under the hood at the firewall is the main relay which powers the ECU ouputs,however it will not effect the starter circuit. If it is an A/T it has an inhibitor switch attached to the trans which the starter circuitgoes through.
travellingfire
Nov 25, 2020 07:26 AM
VegasDriver
Mar 10, 2006 11:10 PM
CP Racing
Jan 9, 2004 02:55 PM
