Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda MPV
  #61
Old 08-24-2009, 01:08 PM
Rafik Rafik is offline
Default 2001 MPV - Key Stuck
Hi all,
First iI ould liek to thank all who wrote those very usefull tips. For my 2001 MPV, the indicator shows I am in Park position, but the ley would not turn to lock, stuck on Acc position. It goes out when I remove the Hazard switch.
I am trying to solve it thorugh ur instructions, but I can not find the pictures. Is there a way to see them orrepost them?
  #62
Old 08-24-2009, 03:15 PM
I wa not able to reach the sensor (the micro switch) so I just disconnected the solonoid. Now I will be able to remove the key in whatever position
Thanks guys. Still pics on how to reach for the microswitch would be appreciated
Cheers
  #63
Old 08-27-2009, 10:30 AM
Babs Babs is offline
Default Pictures
Hi, guys. I have the "key stuck" problem with my 2003 MPV. Thank heavens for you guys - I took the 15A fuse out and could at least get the key out. It is a bit obnoxious to keep sticking the fuse in and taking it out, but a good short-term solution.
I am a mechanical engineer also and would like to fix this without spending $$ - would love to see the photos - are they supposed to be visible on the site or do I have to do something? Perhaps they are no longer up?
I have the power sliding doors - are you saying that if I disable this switch it could cause them to stop working?
Thanks for the help.
  #64
Old 09-13-2009, 02:09 PM
jshortall jshortall is offline
Default MPV stuck ignition key
I had the same problem on my 2004 MPV on two occasions. I finally figured out that there is a control component under the mat on the passenger side. When I get the carpet cleaned, humidity gets into the component and the key won't come out. The problem goes away after a couple of days. The dealer was useless for troubleshooting. Bottom line - I don't get the carpet cleaned anymore.
  #65
Old 10-27-2009, 02:23 AM
grassam grassam is offline
Hi There I have this exact problem and it looks as though your instructions are exactly what I need. I am not able to view the pics that were posted...I may be doing something wrong...thanks very much in advance. Brett
2001, fog, ignition, imglocalupfiles1377e9ea3905b15b41cca4b2daa3f5c0736 0jpgimg, key, light, mazada, mazda, miata, momentary, mpv, protege, remove, stuck, switch, tribute, unable, wont
