Old 07-11-2007, 12:37 AM
Tracker's Avatar
Tracker Tracker is offline
Default Performance availability
OK this thread is for whats available for the mazda3 and speed3 hatchback and sedan, obviously list is subject to change, also parts listed are aftermarket not replacement.
P.S: Do some research first
Engine:
[*]Larger aluminum radiator and performance fans
[*]Short and Cold air intake
[*]Short ram intake
[*]Intake manifold
[*]Turbo kit
[*]Forged pistons (high and low compression)
[*]Forged rods
[*]High output fuel injectors
[*]High performance valves
[*]Heavy duty valvesprings
[*]Heavy duty valvespring retainers
[*]Lightweight crankshaft pully
[*]Heavy duty rod bearings
[*]Stiffer motor mounts (tranny, rear, and top passenger)
[*]Wet or dry oil sump
[*]Balance shaft delete kit (2.3l only)
[*]Lightweight accessory pulleys (alt, water)
[*]High output in tank fuel pump (universal)
[*]High output inline fuel pump (universal)
[*]Cam driven fuel pump upgrade (speed3 only)
[*]N2O (bottles are for babies)
[*]Intercooler meth kit (aka cryo2 kits)
[*]Billet Crankshaft
[*]Oil filter conversion kit (from cartridge to spin-on 2.3l only)
[*]Pre-assembled block with choice of internals
[*]Front mount Intercooler conversion (speed3 only)
[*]Top mount intercooler upgrade (speed3 only)
Suspension:
[*]Strut Tower Bar
[*]Sway Bar Set
[*]Tower Brace Set
[*]Camber Adjustment Kit
[*]4-Point Ladder Brace
[*]Front Lower Tie Brace
[*]Mid Chassis Brace
[*]Rear Lower Tie Brace
[*]Trunk Reinforcement Bar
[*]Sport springs
[*]Fully adjustable coilovers
[*]Rear Anti-Roll Bar Kit
[*]Shocks
[*]Floor brace
[*]Lower Rear Arm Bar
[*]Adjustable front&rear endlinks
Brakes:
[*]High performance blank rotors
[*]Slotted front&rear rotors
[*]Cross drilled and slotted front&rear rotors
[*]High performance brake pads
[*]Stainless Steel Brake Lines
[*]Front big brake kit
Transmission:
[*]Short Shifter
[*]Lightweight Flywheel
[*]Stage 1-3 Clutch
[*]Stronger vavlebodies (automatic trans only)
[*]Torque converter (automatic trans only)
[*]Strengthened 3rd and 4th gears (manual trans only)
[*]Input shaft upgrade (automatic only)
[*]Oil cooler (universal)
[*]Bullet proof tranny
[*]LSD (not the drug )
Exhaust:
[*]Hi-flow cat
[*]Header
[*]Test pipe
[*]Cat-back exhaust
[*]Exhaust cutout
[*]Turbo manifold
Electronics:
[*]Boost controller
[*]Turbo timer
[*]Standalone Engine Management Unit
[*]Twin Power Ignition System (speed 3 only)
[*]Earth wire ground system (universal)
[*]Standalone 2-step and rev match power shift module
[*]Fly by wire response and 100% throttle plate opening module
[*]MAF tuning unit
DO NOT POST/ASK QUESTIONS HERE
All of my statements/comments are based purely on fact
~The Critic
Old 02-22-2008, 07:11 PM
jzoomer jzoomer is offline
Default RE: Performance availability
sorry but who sells the lightweight underdrive pulley?
edit posted in wrong place and cant delete...my bad
http://i124.photobucket.com/albums/p...dy07/phan2.jpg
2007 mazda 3 phantom purple mica
07, 3i, availability, mazda, pulley, sets, underdrive
