TPMS
Old Jul 20, 2007 | 12:34 PM
Craig's Avatar
Default TPMS
I just bought a GT AWD CX-9 in Black Cherry Mica, sunroof, Bose, Sirius, Nav, rear liftgate, and love it!
Q: Is individual TPMS data available in either of the displays (Nav or data line)? Most new cars these days let you see individual tire pressures and let you re-learn, etc. I haven't seen anything on this in the manual and suspect that Mazda didn't completey follow through on this.
Thank you,
Craig
Old Jul 20, 2007 | 01:48 PM
imamgcx9's Avatar
Default RE: TPMS
Theres no diplay for the tpms other than the warning light... manual states:
When changing tires yourself
If you or someone else changes tires, you
or someone else can also undertake the
steps for the TPMS to complete the ID
signal code registration.
1. After tires have been changed, turn the
ignition switch to the ON position, then
turn it back to the ACC or LOCK
position.
2. Wait for about 15 minutes
3. After about 15 minutes, drive the
vehicle at a speed of at least 25 km/h
(16 mph) for 10 minutes and the tire
pressure sensor ID signal code will be
registered automatically.
NOTE
If the vehicle is driven within about 15 minutes
of changing tires, the tire pressure monitoring
system warning light will flash because the
sensor ID signal code would not have been
registered. If this happens, park the vehicle for
about 15 minutes, after which the sensor ID
signal code will register upon driving the
vehicle for 10 minutes.
Old Aug 9, 2007 | 12:55 PM
Craig's Avatar
Default RE: TPMS
Does anyone know of a handheld TPMS reader that we could use to check our tire pressures without taking off the caps and using a gauge? Why not use the TPMS that's already in your wheel? The problem with our system is that it will only indicate if the tire pressure has fallen by 25%.
Lupae3s
Oct 8, 2007 02:17 PM
janz
Dec 6, 2006 11:35 AM
Jim Rowley
Oct 9, 2006 05:59 PM
MrSpike118
Mar 30, 2006 02:32 PM
Lupae3s
Mar 24, 2006 07:28 PM
