radio security code
Old Aug 29, 2005 | 01:33 PM
10009504tyson's Avatar
Default radio security code
i have a 2003 mazda mpv with cd player with the nimber marked 2196 on it. i have locked the security code by entering wrong 3 times. i have tried unlocks posted for similar models in mazdas but they dont work. mazda tell me you must replace the unit. does anybody know different?
Old Aug 30, 2005 | 05:03 AM
Default RE: radio security code
Is this a factory modular audio system? If so where are you posting from? 03 Mpv in US with OE system does not have a lockable audio system with codes that can be input or required to unlock that I am aware of. Mazda stopped using coded audio in the mid 90's.
Old Aug 30, 2005 | 08:49 AM
i am posting from france but originally i bought the car in the uk. it maybe the 2002 model and it is the standard in dash cd unit
Old Sep 1, 2005 | 04:00 AM
Europe market must use different audio system that US. I do not have any radio unlock codes for this year because we do not have locked systems here. Older models (not MPV ) had unlock codes for dealer only use but we do no have these in US in later models. Sorry could not be of more help.
Old Sep 1, 2005 | 09:01 AM
thanks anyway babyhuey. i have looked on a miata website, which we dont have in europe. a player that i have seen there looks identical apatrt from the fact it is a cassette rather than a cd player. dont know if that would tie in with anything you have seen. its all black plastic with 6 memory buttons at the bottom
Old Sep 1, 2005 | 02:56 PM
Finally got an 03 in shop. Sending picture of our audio unit. The number in upper right corner is 1168. These are called modular audio unit because you can add accessories onto the base unit. Base unit is standard am/fm with 18 presets. Usually come standard with single cd in upper area but can change to a six disc in dash for extra money. Can also add either a cassette or minidisc into bottom section. Your units may be different but I find it very hard to believe that a manufacturer would make a radio that becomes a boat anchor if you accidently forget you code. Older model Mazdas had radios with 4 digit locking codes that you could activate but a master unlock code was available to the dealer in case was locked up. Try checking around a bit and maybe even contact Mazda France and see what they say.
[IMG]local://upfiles/1377/DF255E1A5385468A8D7D1E64F997653E.jpg[/IMG]
Old Sep 7, 2005 | 07:32 PM
hi baby huey thanks for your time. that looks identical to my unit. i have tried all the dealers that i have acess to and they all say the same. about 700 dollars to replace and thats the only option. im sure they are not bieng exactly truthfull so if you mange to crack it i would be a very happy person!
FCBarca
Sep 26, 2009 07:30 PM
sincitykilla21
May 8, 2007 11:24 AM
Trevor
Apr 8, 2007 07:53 AM
kyleskin
Jan 11, 2007 06:59 PM
pwb2b@mtsu.edu
Sep 11, 2006 03:51 PM
